Help please, multiple component connections.
Discussion in 'LCD & LED LCD TVs Forum' started by Matt TRD, Jul 4, 2005.
Tags:
  1. Matt TRD
    Matt TRD
    Jun 28, 2005
    954
    Poole
    +68
    Ok i looked through the FAQs but could not find an answer.
    I want to connect all three of my consoles via component for progressive scan the LCD only has one component input.
    Will i have to connect each console as i use them or is there a way around this as i would like to have it all set up without messing around with cabling when switching consoles.
    For example i currently use a Joytech scart box which automatically switches inputs depending upon which system i power up.
    Sorry if this seems a stupid question but it has been troubling me for sometime now.
    Forgot to mention my LCD TV is an Hitachi 32ld7200.
  2. DanH
    DanH
    Feb 16, 2005
    604
    +56
    You can get component switchers just like the scart switcher you already have. You can also use the VGA connection on the Hitachi as another component connection too. This is normally not a problem for dvd players, as component to vga cables are easy to find, but might not be the case with your console(s).
    Its also worth noting that the VGA connection on the Hitachi cannot take 720p @ 50hz. It can take 720p60 though. (Aswell as all the others - 480i/p, 576i/p 1080i/p at 50 & 60hz)
    Edit - Here you go: http://www.lik-sang.com/info.php?category=83&products_id=4088&
  3. Matt TRD
    Matt TRD
    Jun 28, 2005
    954
    Poole
    +68
    Thankyou very much mate that's a great help, i have just ordered one.
    All my games are US NTSC running at 60 hz so should all be ok.
  4. DanH
    DanH
    Feb 16, 2005
    604
    +56
    Np. :)
    The component connection accepts everything anyway, its only the VGA that cant do 720p50.
