Help please installing Creative XFi soundcard - keeps crashing
Discussion in 'Computer Components' started by newstuart, Mar 13, 2006.
  1. newstuart
    newstuart
    Apr 22, 2004
    1,806
    Northumberland
    +84
    Hi all, I hope you may be able to help me, I built a new pc yesterday around a new Asus A8N-SLI board and have spent the last few hours trying to install a new Creative X-fi (xtreme music edition) soundcard. Every time i try to install the software the pc crashes at 25% of the way through loading. When it re-boots I get asked to insert the Creative disc that came with it.
    I do this and am asked to insert disc containing D:\Win2K_XP\i386.
    I have tried both the install disc and the latest drivers
    can anyone please offer any advice on where "D:\Win2K_XP\i386" is please ?
    :lease:
  2. JorisS
    JorisS
    Nov 20, 2004
    1,570
    48
    Uppsala, Sweden
    +38
    newstuart, I'm guessing that it's the Windows installation cd?
    What version of Windows are you running? I've just installed an X-Fi Fatal1ty and it worked flawless with Windows XP Professional with SP2 as OS.
    Try using the windows cd when it asks for that D:\Win2K_XP\i386, might work. Then again, it shouldn't crash to begin with, something obviously is buggering the installation... could be anything really though :(
    I actually have almost the same motherboard as well, by the way... A8N-E
  3. TiSwAs
    TiSwAs
    May 2, 2005
    387
    Blackpool
    +20
    Is your version of XP OEM or Retail?
    The i386 directory which the system is refering you to are the installtion files for XP.
    If you insert the Microsoft XP installed disk into the CD drive (i presume that your CD drive is drive D?) then go to My Computer > right click and do a search for the i386 directory - make a note of it.
    take out the xp install disk and run the creative setup and when it asks for the the D:\Win2K_XP\i386 insert the XP install disk and browse to the location you just found previous - you may need to keep swapings disks but that should work.
  4. newstuart
    newstuart
    Apr 22, 2004
    1,806
    Northumberland
    +84
    thanks guys , sorted now - although not exactly sure how !! after pc was left off over night I tried to re-install the card just now and it all went through fine ?? Strange but true and at least its sorted now :thumbsup:
  5. JorisS
    JorisS
    Nov 20, 2004
    1,570
    48
    Uppsala, Sweden
    +38
    I just stumbled across this text from Creatives homepage as well:
    Although you already sorted the issue, perhaps this is of use to future readers of this topic :)
  6. newstuart
    newstuart
    Apr 22, 2004
    1,806
    Northumberland
    +84
    Ahhh That wmay explain things then, Thannks for the info and I hope it may be of use to anyone else who has a problem :smashin:
