Help please... im tearing my hair out now!
Discussion in 'LCD & LED LCD TVs Forum' started by MattDJ, Feb 10, 2005.
Tags:
  1. MattDJ
    MattDJ
    Jan 1, 2005
    260
    As you will see "Bye Bye 9986..." well its not quite what it seems... please please help. I want to get my problem sorted asap.
    Does anyone have the 37inch Philips 9986?
    Does it need to be version 2.1?
    Does it hum???
    Thanks!
  2. killer10971
    killer10971
    Dec 29, 2004
    1,050
    +33
    i have the 37pf9986
    its ver 2.1
    and it dosnt hum , when its muted its silent , when ambilent is first turned on a slight tizzing sound which either calms down as the tube warms up or my ears get used to it (or turn volume up)
    very quiet
  3. pacman
    pacman
    Nov 22, 2004
    37
    Hi Matt,
    I have a one!
    Not sure wther it 'needs' version 2.1 but mine has that version number.
    Cannot detect any humming, although possibly too many discos in the 80's may have had a very minor affect on my hearing.
    Regards,
  4. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Matt,
    So far I haven't come across any 37" 9986 with this problem. It's possibly a different component that operates in the 37". Do you have the 32" at the moment?
    Jimmy
  5. Alan D
    Alan D
    I've got the 37PF9986 - no hum. It's v2.0
  6. Tony B
    Tony B
    Oct 29, 2004
    549
    +21
    I have the 37pf9986, v2.0 and no hum
  7. Alpino
    Alpino
    Dec 9, 2004
    5
    Istanbul, Turkey
    I have 42/9986 with version 2.0 and no hum.
    BTW, it seems that latest sets come with version 2.0 as opposed to 2.1. I had mine (with 2.1) changed after 30 days useage due to a display malfunction and the new one has version 2.0 ?!
  8. MattDJ
    MattDJ
    Jan 1, 2005
    260
    I still have the 32" at the mo... just deciding on whether to "upgrade" to the 37"
    or get a different one altogether (maybe titanium 37, although about £3100 EEK)
