Help please, im going round in circles
Discussion in 'Desktop & Laptop Computers Forum' started by JSW, Apr 8, 2002.
  1. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Have connected my pc to my Sony RPTV and just cant seem to get the correct resolution :(
    Im using a Radeon 8500 and powerstrip, but no matter wat i try i either have black bars at the top and bottom of the screen or the picture is too big width ways to show it all at once?
    Could someone possibly tell me wat settings i should be using?
    Many Thanks
    Bry
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,148
    UK.
    +2,670
    If the film is 2.35:1 ratio (check on the packing) then you will get black bars top and bottom on a 16:9 or 4:3 tv.A 16:9 film should fill your tv (if it's a 16:9 widescreen tv).
    The only way to get full screen is to 'zoom' into the image so that you lose the sides of the film image outside of the screen area and bring the top and bottom of the image to line up with the top and bottom of the screen. You should be able to do this using YXY or Zoom player.
    I recently had a friend round to see my projector set-up, and he prefered the zoomed in method for 2.35:1 films on my 16:9 screen.
    HTH
    Gary.
  3. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Still confused :(
    What should my desktop resolution be?
    What mode should my tv be in 4.3, Wide, Zoom ?
    What software dvd player should i use ?
    What other programs should i use/get?
    I also want to play games on the tv.
    Bry
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,148
    UK.
    +2,670
    I'm assuming the tv is a standard 4:3 ratio, so with widescreen DVDs you will always get black bars top and bottom or lose some of the image either side if you fill the screen.
    You can use a ratio of 800 x 600 on the computer (how are you connecting to the tv?), which is a 4:3 ratio same as your tv. What software are you using to playback your DVDs?
    Games shouldn't be a problem as most are 4:3 anyway.
    Gary.
  5. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    tv is a 41" RPTV 16:9
    Power DVD 4 XP
  6. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Please someone must know :(
  7. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    The normal solution for this is to untick the setting "keep aspect ratio", I can't remember the exct name of the setting for PowerDVD XP but its something like that.
    Jeff
  8. Paul O
    Paul O
    Nov 2, 2000
    481
    UK
    +21
    Hi JSW.
    I have an All-in wonder card, so I don't know if this is the same but;
    On my card, due to the way it works in the UK, there are black bars at the top and bottom, even on full screen. There is a hack to get around this, but I don't know it.
    Otherwise, the resolution I think needs to be 800x600. You can then adjust the size of the screen using the Advanced tab in the settings. In my experience though, you won't get it exactly bang-on.
    Hope this is of some use!
    Cheers,
    Paul.
  9. jrwood
    jrwood
    Sounds like you need to enable the hidden TVOverScan funcion. Choose 800*600 resolution
    regedit
    HKEY_Local_Machine\System\Current-ControlSet\Services\ati2mtag\DeviceX
    where X is either 0 or 1 or maybe something else..
    or if you have some special installation
    HKEY_Local_Machine\System\Current-ControlSet\Video\xxxxxxxxxxxx\0000
    xxxxxxxxxxxx - take the last one (this is maybe the actual driver) - if not sure - put the new dword in every installation - no problem
    create a new DWORD
    name it: TvEnableOverscan
    give it the value: 1
    Reboot the PC and you should have an overscan button in the TV-Settings. Again things might be slightly different as it depends what Operating System you are running etc...
    James
  10. jrwood
    jrwood
    Also if your not comfortable with editing the registry then you can always use one of the many radeon tweaker programs to do this for you.
    http://www.rage3d.com/radeon/r3dtweak/ is a good example which allows the TVOverscan button to 'appear' in the control panel.
    James
  11. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Cheers guys have now enabled overscan :)
    Unfortunately cant see my taskbar now cause its off the bottom of the screen :(
    also im unable to change the screen position or size in display settings with overscan enabled :(
    Any ideas what i need to do?
    Bry
  12. jrwood
    jrwood
    From memory I dont think you can change the position of the screen using the screen adjustment ATI control panel. I don't use TV output anymore since I bought a front projector but you could try using powerstrip to move the picture around the screen?, just go into display options then advanced timings I think.
    As for the taskbar being off the screen you could always move it to the top or sides, depending on what you preferred. To be honest when I had mine setup with the TV I just had shortcuts on my desktop for movies/dvd player and winamp. If I wanted to shut the PC down I just pressed ALT+F4 and then the letter U for shutdown in Windows XP!.
    Another idea is to go into the control panel>display>appearance? I think and change the font setting from normal to large or extra large.
    If there's a will theres a way :D
    James
    p.s is the 1070 a good amp?, Im still thinking about an AMP but I`m not sure which one to get still!. I think I really should get one which has DPL2...choices choices
  13. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    I think the 1070 is a damn good amp and am very happy with it :)
    Not sure wat all the fuss is about dpl 2 I can live without it.
