help please has anyone set up pronto to work with windows media center?
Discussion in 'Home Cinema Control & Remote Controls' started by newstuart, May 20, 2004.
  1. newstuart
    newstuart
    Apr 22, 2004
    1,797
    Northumberland
    +82
    Hi all
    Im desperatly trying to set up my pronto to work with my new media center pc however im having a nightmare learning the codes.The pronto shows it had learned from the original remote but when it try to use it i get problems.The main thing i notice is the cursor will work once then stop(as if the original used more than one code for the same function?).any ideas or expiriences would be much appreciated
  2. The Robman
    The Robman
  3. newstuart
    newstuart
    Apr 22, 2004
    1,797
    Northumberland
    +82
    thanks alot mate that looks like it will sort it nice one
