Help please. Dscaler won't run
Discussion in 'Desktop & Laptop Computers Forum' started by Messiah, Jun 22, 2002.
  1. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    I have downloaded and installed Dscaler. However, when I run DScaler.exe the window opens up (I can see the menu items) but then immediately disappears. Nothing on the taskbar. It is as though it is shutting itself down, yet if I go into Task Manager it is showing as 'running'
    I have an nVidia GeForce 2 MX400 graphics card. Does Dscaler work with this card?
    Any help or advice appreciated. Thanks.
    Neil
  2. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Same happened to me buddy.
    Then I realised I needed a capture card. Don't believe your card has an input..maybe wrong.
    Bought a Hauppage and plumbed my composite sky thru it.
    Works a treat.
    Ta
    Chris
  3. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    Thanks m8. You're absolutely right. How silly of me not to realise that without an input on the video card there's nothing for it to work on. I am considering getting another card but was just interested in seeing what Dscaler did.
    Guess I'll have to bite the bullet and buy a card. Any suggestions? I like the Radeon All in Wonder PVR card (about £300) but not sure if Dscaler will work with it.
  4. oreoboy13
    oreoboy13
    Theres a list on the site, but no Dsclaer doesnt work with it, wrong chipset.
  5. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    No need to go that far.
    The capture card works with your existing card as the output device.
    Something as simple as a WinTV, 50 quid will be OK.
    Get one with an S-Video in if you can. Mine only has Composite in but that doesn't bother me.
    Cheers.
    PS..I think Pinacle do a series of good cards.
  6. Timh
    Timh
    Sep 14, 2000
    5,267
    3
    3
    Altair-4
    +339
    I went for the pinnacle rave card here and it does have s-video in.
  7. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    Any ideas if it will work with the Hercules 3D Prophet FDX 8500LE 64MB?
    It is based on the Radeon chipset. Seems quite a good card available for £90 at PC World. Features DVI output as well as S-Vid in and out.
    Thanks.
  8. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    From my investigation of tv cards it looks like DScaler does not work with any all in one ATI based cards. Only the ATI TV Wonder, which has a brooktree chip on it. Sorry,
    Chris
