Baz59
Hi everyone,
Looking for recommendations regarding a new sub for my set-up. I have recently changed my fronts, centre and rear speakers all of which I am very happy with. I am currently using a KEF 20b (specifications below) purchased new way back in 1996 so pretty old and dated!!!
Thinking this may now be the weakest link I am wondering if an upgrade would achieve a 'big step up' performance wise? Please find below my current set-up along with my 'man cave' layout, also included are pictures of my seating area and existing sub for reference. I currently only use the sub for movie's and listen at moderate volume levels. My QA 3050i's are sufficient in the bass department for music but I may experiment with the new sub if there are gains to be made.
Having done some research my current choice would be a BK Double Gem? Not too big and would fit in either of the positions as seen on my floor plan. However open to suggestions.
AV Amp: Denon AVR X3300W
Amplifier: Audiolab 8000A Used direct for front speakers (both music & movies)
Front's: Q Acoustics 3050i
Rear's: Q Acoustics 3010i
Centre: KEF Q650c
Amos Heights (front): CA Minx 21's
Specification: KEF 20B
System type: Active subwoofer
Enclosure type: Closed box
Dimensions (H x W x D): 326 x 302 x 335mm (13 x 12 x 13.2 inches)
Weight: 9.3kg (20.5 lbs)
Drive Unit: 250mm (10”) long throw
Amplifier: 70W
Frequency response: 45Hz to 150Hz +/-3.0dB (-6dB at 36Hz)
Maximum output: 107dB
Finish: Video Grey
System: SP3259
Drive Units: B250 bass unit (SP1420)
Amplifier: SP2262(230V)
A special Thank you to all respondents!
Centre: KEF Q650c
Amplifier: 70W
Finish: Video Grey
System: SP3259
