Help please - Are these discs any good ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by ianrob, Dec 8, 2004.
  1. ianrob
    ianrob
    Hi all,
    Well, finally I have taken the plunge and ordered a panny 95, due today.
    Now I have to go and purchase dvd's and an extra scart lead to try it out.
    I am hoping that Argos will get some more stock in of RAM discs, but
    to try it I need to purchase some dvd-r's.
    As I live close to Scan's offices in Horwich I have seen the following three
    products on there wesite which seem to offer a good price. Two being
    ritek dyes/grade A and Verbatim x8 media with Jewel case.
    I would appreciate your opinion on whether any of them are a suitable
    product to use.
    Links:
    http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=143722 50pcs DVD-R Roll (Shrinkwraped) x4 Speed Orange Tango's , Certified Ritek Branded Dye
    http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=145744 25pcs DVD-R x8 Roll (Shrinkwraped) 'ANV' Brand,Certified GRADE 'A' Ritek Media (G05 Dye)
    http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=115989 10Pack DVD-R Verbatim x8 Media Printable in Jewel Case
    Thanks for any advice you can offer :lease:
  2. HMHB
    HMHB
    Nov 11, 2001
    26,645
    Nottinghamshire
    +5,362
    I've used Verbatim and Ritek G04/05 dye DVDs on my E85 with no problems, but I've always used the 4 speed ones. I believe the 8 speed ones are fine but the machines will only write at 4 speed.
    Edit
    I've not used that particular brand though, and I've always tried to use the "A" rated ones when using non-branded.
  3. ianrob
    ianrob
    Thank for the quick reply John, :thumbsup:
    With regards to the first item:
    50pcs DVD-R Roll (Shrinkwraped) x4 Speed Orange Tango's , Certified Ritek Branded Dye.
    How do I confirm which type of dye is used (G04/05/???).
    I will probably get the verbatims today, this is future reference.
    Thanks. :clap: :hiya: :clap:
  4. HMHB
    HMHB
    Nov 11, 2001
    26,645
    Nottinghamshire
    +5,362
    I tend to use SVP for my blank DVDs as you can click on the pics of the DVDs and it tells you all about them.
    Here is a link to their DVD-R section
  5. Bosco
    Bosco
    GO4/GO5 it doesn't make a difference which, both should be fine with your machine. As already advised, SVP are a great place to do business with and they show the dye used on all disks, they also sell a 10pk spindle of Ram disks for £14 and if you join their buyers club (which is free) they often run special deals such as 99p shipping.
