Question Help Please, Android Phone with Screen smashed and need to recover data
Discussion in 'Mobile Phones Forum' started by mr starface, Dec 17, 2016.
  1. mr starface
    mr starface
    Mar 29, 2007
    1,644
    +462
    Not a good day, somehow managed to badly mangle up my LG G3. Amazingly enough it still boots up but as the screen is completely smashed I cant navigate using it!
    Obviously my first thought it get my data backed up asap but no idea how to do this....
    The LG PC Suite wont detect the phone as I cant put the phone in media sync mode when I connect it to my PC (the PC does detect the phone though!). Also cant do it over wifi as I had it switched off when the accident happened.
    Tried something called Dr Fone but it did not support my phone.
    Tried Android Control but its too complicated for my small brain.
    Any help/advice much appreciated!
  2. cbmvic20
    cbmvic20
    Aug 6, 2013
    240
    +19
    Can you not just pop the SD card out and use that?
    If you're comfortable using the command line, you can backup Android using a terminal and ADB if you had the developer options and USB debugging enabled on the G3. See How to Backup Your Entire Android Device to PC for example.
    Otherwise, there are specialist services that'll recover the data for you at cost (cheapest around £100) or if you have the tools, get a replacement screen and fix it?
  3. cosmicma
    cosmicma
    Dec 21, 2004
    703
    46
    greater manchester
    +203
  4. muggle296
    muggle296
    Jan 23, 2018
    中国
    如何做Android的手机通讯录恢复
    事实上,关于联系人:?数据存储在哪里,联系人存储在哪里大多数人会说Android的设备或“人”应用程序的“联系”文件夹实际上,除了我们可以在联系人文件夹或人类应用程序中看到的联系人信息之外,我们的手机存储器中还有一个联系人数据库。从联系人文件夹或人事应用程序中删除联系人时,联系人数据尚未从数据库中删除。
    第1步:将您的Android的手机连接到计算机
    当您意识到数据丢失时,请停止使用手机。在Windows / Mac电脑上快速安装并运行FoneDog Android数据恢复
    第二步:允许超级用户请求
    FoneDog Android数据恢复将需要进入您的设备的权限。去Android的手机。在弹出提示中选择“权限/授权/授权”。
    第三步:选择要扫描的文件类型
    要检索的Android通讯簿,首先需要为扫描选择相应的文件类型。检查列表中的联系人,然后单击下一步
    第四步:选择删除和丢失的文件恢复
    扫描完成后,在左窗格中选择“联系人”。然后,您可以预览电话簿中的所有项目。接下来,选择任何你想要的,然后点击“恢复”让他们回来。
    更多信息:FoneDog Android数据恢复
