Help please-absolute beginner
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by cvickery, Jul 7, 2002.
  1. cvickery
    cvickery
    My son is due to start an AS level in Film & Video in September. We've never owned one before but now need to get a camcorder before then. All I know is that s/h is ok and that they will be using Premier 5 to edit on PC. It will prob only be used for this course but I might have a little play. Any help with regard to format/features would be appreciated.
    Chris
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    Look for a model with DV In/Out.
  3. CamcorderNovice
    CamcorderNovice
    As you can tell by my nickname, I'm somewhat of a beginner myself when it comes to camcorders. However, I do have some good advice: -
    The magazine 'what camcorder' (hee hee) is very very useful. If you fancy a particular type of model try looking at the reviews.
    I found talking to alot of people about camcorders very useful.
    I also found it useful going round to various shops and asking their opinions. This also lets you have a good look at the camcorders available because there are alot on the market!
    Hope this helps
  4. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    +32
    Camcorder Novice,
    Sensible advice, no-one will argue with you there.
  5. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    For best value, look at 'run out' models I.e. last years. If the budget will stretch to it, go for a 3 chip model. Panasonic or Sony are to be preferred but the Canon would be equally acceptable. You should be able to find the Panasonic 3 chip for anything from 900 to 1300. Don't forget to budget for extra battery(s) (High capacity) also, a decent tripod and probabaly wide angle converter.
