Help please 2 sky+box problem
Discussion in 'Sky Digital TV Forum' started by dragon1, Dec 19, 2003.
  1. dragon1
    dragon1
    We have 2 sky+ boxes in our house and we are having a problem with handheld remotes interferring with each other, ie 1 remote for one room will change channels on a box in another room.
    Dose anybody have any ideas how we can cure the problem
    Many thanks
    Dragon1
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    how far away are the rooms and do you use link eyes on either box? There is a very simple solution, but its a tad expensive, though anyone with 2 sky+ boxes shouldnt worry about finding the cash!
  3. gbmitie
    gbmitie
    Apr 25, 2001
    1,141
    49
    republic of ireland now
    +62
    u will have to position boxes in such a way that the remote window is hidden from other remote, very tricky as they are almost omnidirectional.
    U could try a piece of tin foil with blu tack over the receiver on each box and reduce its receiving capabilities ie just leave a small part of receiver open. I can do this with 2 boxes sitiing on top of each other! but it takes skill.
    If u are bamboozeled by this post back.
    gb--
