Hi Guys,
Need a little bit of guidance / advice on this. Putting together a PMC 5.1 system with FB1+'s as fronts and rears with a matching TB2C+ centre. I've got a budget of about £1,000 for the amp and don't mind buying second hand. The majority of my listening will be Sky TV, games and movies (60/20/20 split) in an average size living room. I'm very weary of spending extra on performance i won't be able to appreciate due to my listening habits and speakers.
For context, I had an NR609 (with a MA BR5 AV speaker set up) and found it just about sufficient. I'm not sure it (the 609) will be bring out the best of the PMC's though as i've heard they like quality amplification
Within my budget, would i be better off with an integrated or processor+power combination. My research so far has turned up the following questions:
Integrated:
Onkyo 818.
I like the 818 because it's got a good range of inputs and outputs and also has XT32.
It's also quite powerful at 180W per channel (though I suspect that's with two channels driven). Does anyone know what it's capable of with 5 channels driven (higher or lower than the 70W per channel of the MRX 300)?
The ability to bi-amp the fronts (and the centre?) is also handy but i worry again about the power trade off with 7 channels driven.
I don't however need a lot of the bells and whistles advertised with the amp and don't want to pay for them.
Anthem MRX 300
These seem to be very highly regarded as well especially for their SQ and Room EQ. The inputs and outputs are sparse but will be fine for what i require (Sky, Xbox, PS3 and HTPC). ARC i've heard is only slightly better than XT32 but more complicated to set up. I don't mind the set up as i'm sure i'll find plenty of help on here
My greatest concern with the MRX is the reported power rating. 70W per channel sounds low for 5 channels driven and 60W per channel even worse with 7 (front two bi-amped if this is possible with the Anthem?). Will 60W be enough to drive the PMC's comfortably?
Another concern is that ARC only eq's down to 20Hz. I'm looking at a JL112 sub which should be comfortable down to at least 16hz in-room. Is this something that should concern me?
Anthem MRX 500
I can just about stretch to this. Basically as above but with 15W per channel more power. Will the additional power make a difference with the PMC's or will I be better served spending the additional cost over the 300 (about £300) on a power amp if such amps do exist at that price point?
Processor + Power Amp
To be honest i'm quite clueless on these. I've read about the Emotivas but they're only available in the US. After shipping etc a processor + Power amp combo would be significantly above my budget.
I don't know of any budget processors + power amps produced in the UK. Any recommendations?
Should I be thinking about increasing my budget to accommodate separates (pro + power) or will the additional benefits be marginal and limited by my speakers and listening level (compared to an integrated)
Any others options I should be looking at?
Apologies for the long post...just wanted to get all my thoughts out there. Many thanks in advance for the help!
Integrated:
Onkyo 818.
Anthem MRX 300
Anthem MRX 500
