Help:Pioneer 811 No Sub Output with CD's???
W
WBC
Guys,
Got my sub setting to ON on the amp. Watching DVD's is fine, amp works a beauty.
I have my Xbox (using xbmc) plugged into the 'CD optical in' on the amp but whenever I play music there is NO output from the sub, any ideas, I'm completely stumped????
Thanks in Advance
Stace :D
smiley1
It forces sub output to on, since setting "on" in some cases doesn't output LFE channel.
This setting existed on 812 (which i owned), i think it should be on 811 also.
Astaroth
Also need to make sure that at least 'some' of your speakers are set to small. If they are all set as Large then the amps algorythm may not generate a LFE channel
sarll
When playing with a 1014 I found the plus setting to be similar to selecting LFE+mains on other amps.
Similar threads
Podcast: LG SN7CY Soundbar Review, Hisense 55U7Q, LG Nano90, Best of the Month, B+W Sigourney Weaver
