Help pioneer 433mxe broke ???
Discussion in 'Plasma TVs' started by 2Ben, Oct 7, 2003.
  1. 2Ben
    2Ben
    Help my plasma stop.....
    the wife was watching a show and suddenly the screen made a horrible picture in 2 seconds and turned it self off and now blinks 5 short times in the standby LED HELP WHAT has happened.
    THANKS Torben
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,807
    The Borders
    +2,471
    Torben
    Your display is 'protecting' itself - usually a sign of a Power supply failure.
    First off talk to your Pioneer dealer and if that doesn't get you on the road to a repair then talk to Pioneer UK and they will put you in touch with Barron McCann; who carry out all warranty work (and non warranty work too).
    Best regards
    Joe
    Pioneer UK (Service) - 01753 789 810
    Barron McCann (Service) - 01322 866 577
  3. 2Ben
    2Ben
    Thanks for the help Joe i have called Pioneer and they also said that the PIO 433 have to go to repairs ....
    Torben
  4. miniman
    miniman
    Apr 14, 2003
    567
    Birmingham
    +7
    just had this happen to mine, barron mc cann fixed it and I had it back in a couple of weeks, bit nerve wracking though!
  5. MrAnderson69uk
    MrAnderson69uk
    May 12, 2003
    190
    +15
    Hmmm, getting worried now!
    So, I've got a few questions...
    Is this a common problem with PIO 433 ? ...is it mainly MXE's, HDE or either ?
    How many hours had elapsed on your panels before they broke ?
    When should I expect mine to go ? ...I got it 2 weeks into June 2003 and use it quite a lot as it's the main telly ?
    Has anyone else had similar problems but don't want to loose face having bought what's regarded as one of the better panels ?
  6. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    No, it's really not that common. I'm sure Joe would say the same, we've both had rental fleets, which take some real stick, and seen loads in domestic installs, in fack my brother in law has one. They are at least as reliable as any other plasma, remember you only hear of people with hassle, it's disproportionate. Check the Hitachi thread, there are so many of them there are bound to be a few less happy. Relax, 99% certain you will be fine. The only plasma I know of and consider unreliable is the Panny 50". I've installed 8, and 5 have gone back at least once...
