Help - picture delay when gaming with projector
Discussion in 'PC Gaming & Rigs' started by loftfuton, Aug 27, 2004.
  1. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Chaps
    Some advice please.
    Playing Far Cry through Sony VPL-VW10HT projector fed by RGB analogue output from the DVI-I connector of a Radeon 9800pro card. Stacks of RAM and 3.4 processor.
    Somewhere along the line I am getting a delay of about .25 sec between moving the mouse and the cooresponding picture move which makes me easy meat for the Trygens.
    Anyone else having problems like this ??? is the delay in the DVI-I output (although it is the analogue signal I am using) ???, or the projector processing ????....or anywhere else ????
    Harry
  2. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,737
    71
    Land of the Living, Essex
    +35
    not using a wireless keyboard are you?
  3. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Am actually, the fast Logitec one whose name escapes me (700 perhaps ??), but even used close to the base station there is still the delay. I had heard that this mouse was good for gaming ??
  4. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,737
    71
    +35
    All cordless solutions have a delay, best get yourself a keyboard and mouse with a usb extension cable or something.
    BTW anoying isnt it
  5. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,681
    aka Billy Science - Suni ojna Tas
    +430
    Nope - most modern wireless mice and keyboards update at the same rate as usb - certainly shouldn't be 1/4 of a second.
    Although I don't use it all the time for gameing, I have a Logitec mx700 mouse and there is no delay ( perceptable ) in mouse movement to cursor.
  6. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,737
    71
    +35
    Well I have that one too, it is very noticable as it is on all cordless mice, plugin a wired keyboard to find out for yourself.
    Why do you think they dont recommend wireless keyboard & mice for gaming on Quake/Unreal/Half Life style sites?
  7. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,681
    +430
    THERE IS NO NOTICEABLE DELAY on Logitec mx700's ... and afiak the same goes for all the recent models for most manufacturers.
    The data is sampled as FAST as if not FASTER than USB frequency on the latest wireless mice.
    So it can be a QUICKER response than a CORDED USB MOUSE.
    I sugguest either upgradeing your hardware or checking your system drivers - as there appears to be an issue with your computer.
    Also read the instructions - there may well be settings for your mouse such as
    - enhance accuracy
    - mouse speed
    etc that you need to adjust to attain a properly functioning mouse for your needs.
    NOTE: the logitec mx700 samples and adjusts movement 30 times within 1/4 of a second - even old wireless mice do it 15 times in that period.
  8. Garrett
    Garrett
    Apr 21, 2001
    39,850
    2
    167
    The best thief you’ll never see.
    +6,517
    I have a mate who played CS on a number of severs and was number one player on them and he used a MX 700 cordless mouse. If there was any delay he would have not attained such lofty positions.
    I too have a MX 700 and there is no perceivable delay on it at all.
  9. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    I play COD with the logitech wireless mouse and keyboard with no problems at all. Make sure you are within range and it should all be fine. When I'm playing on the projecter I move my mouse docker (which is also the signal) closer to where I am sitting and that seems to work fine.
    CaM
  10. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Thanks for all your replies. I have gone along the route of the physical placement of the receiver to optimise the signal - Logitech even suggested angling the docking station away from the vertical, which in some instances they say improves the signal reception, and I think laying the unit on the desk horizontally may have helped a little, but not enough . Will check software upgrades and compatability now as suggested.
    Thanks again
    Harry
  11. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,574
    The Borders
    +3,029
    loftfuton
    Do you get the same delay if you use a local monitor rather than the projector? Its not unknown for a Display device (plasma or projector) to add Video Processing time to a PC signal.
    Best regards
    Joe
  12. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Joe
    Everything seems fine on the crt monitor I use. Have sent questions to both the video card manufacturer, and Sony for the projector, so perhaps something might come from that.
    Harry
  13. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,574
    The Borders
    +3,029
    loftfuton
    What signal are you sending to the projector - if its equivalent to a video signal 480P, 720P etc the Projector may be adding extra processing to the signal; switch as many 'filters' on the Sony off as you can..
    Also try altering the signal to different resolutions and see what happens.
    Best regards
    Joe
  14. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Joe
    Dropped the signal resolution down and that solved the problem !! Had altered this before but obviousley not by enough.
    Thanks for that
    Harry
  15. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,681
    +430
    Just an ironic side note about your Sig
    ...... its ASCii ;)
  16. Marc
    Marc
    Jul 8, 2004
    11,719
    Titchfield
    +1,101
    and the binary one is funnier :p
