P
pdvuk
Hi guys, i have just put my PHILIPS 50PF7521D/10 on the wall after they delivered it today. And it wont switch on.
YES, i did check if the power cable is plugged in.
It hasnt even switched on once...
if have studied the manual, check the fuse on the plug, checked the wall socket, nothing.
It doesnt even make a noise when power cable is plugged in(for example if screen was busted, it would still make a noise wouldnt it?)
Any one had siomilar problems with phillips???
Please help, i feel like throwing it in the skip...
(oh and all the relevant help lines are closed as it is sunday, and im scared i wont be able to get them to fix it before xmas)
Pierre
Pierre
