Help - PCM or Bitstreaming
Discussion in 'Blu-ray & DVD Players & Recorders' started by Theriomophic, Sep 23, 2005.
  1. Theriomophic
    Theriomophic
    Aug 9, 2004
    138
    +6
    I have just purchased a new Samsung HD950 and have it connected via HDMI to my LE40r51B HD set. I have it also connected via optical cable to my sony amp.
    Please can you let me which setting is best? :confused:
    Many thanks
    T
  2. MrNPG
    MrNPG
    Apr 13, 2005
    714
    Poole, Dorset
    +44
    As you have it connected to your amp, you should use Bitstream.
  3. Theriomophic
    Theriomophic
    Aug 9, 2004
    138
    +6
    Thanks for the reply.
    Just out of curiosity - can you please tell me why? As I really have no clue about this sort of stuff?
    Thanks again for the prompt response. :thumbsup:
    T
  4. MrNPG
    MrNPG
    Apr 13, 2005
    714
    Poole, Dorset
    +44
    To be honest with you, I don't really know the reason why, just know that bitstream should be used when you connect your DVD player to an A/V amp.
  5. Theriomophic
    Theriomophic
    Aug 9, 2004
    138
    +6
    Thanks anyway. :thumbsup:
    T
  6. Spacedog
    Spacedog
    As far as i know, you need to use Bitstream in order to enjoy 5.1 sound (DD or DTS). If you set the DVD player to PCM, you'll only get 2 channel audio from the DVD disc into the A/V amp (and also into the stereo downmix analog outs of the player), even if the audio soundtrack playing is 5.1.
    PCM is ok when you have only a stereo speaker setup. :thumbsup:
  7. pknarb
    pknarb
    Aug 29, 2005
    47
    When set to "bitstream", the DVD player will stream sound data unaltered to the amplifier.
    When set to "PCM", the DVD player will "downmix" to two channel PCM (Stereo) and sound will only be heard from left and right speaker.
  8. MrNPG
    MrNPG
    Apr 13, 2005
    714
    Poole, Dorset
    +44
    I thought it was something to do with the "downmixing" but wasn't sure. :)
  9. Spacedog
    Spacedog
    pknarb, if you're for example playing a DVD disc with a Dolby Digital soundtrack, which has a 96khz audio data sampling, and you choose "PCM", what will be the sampling of the stereo downmix?
    This question arises because of the option "LPCM out" that you also have in most players. This option lets you choose from 48khz, 96khz and 192khz but i'm not quite shure what it's used for... do you? Does this option only applies when you choose "PCM" instead of "Bitstream"?
    Thankx!
  10. Theriomophic
    Theriomophic
    Aug 9, 2004
    138
    +6
    T
  11. Spacedog
    Spacedog
    Anyone?? :confused:
  12. pknarb
    pknarb
    Aug 29, 2005
    47
    Spacedog, the HD950 has a setting called "PCM Down Sampling". Judging by the name of the setting it should only alter the sampling rate of a downmix and not a "bistream".
  13. Stingingwasp
    Stingingwasp
    Mar 17, 2005
    72
    Just for info Theriomophic, as you have the DVD connected via HDMI, when you select Bitstreaming you will get a message saying "HDMI audio not supported". it only stays there for a few seconds.
    You can ignore it this warning. its annoying bug that the HD850 has, and i belive it is present in the 950 also.
  14. Theriomophic
    Theriomophic
    Aug 9, 2004
    138
    +6
    You guys are awesome and foooking clever :lesson:
    Thanks for all the help fellas. :clap:
    T
  15. Spacedog
    Spacedog
    What about Dolby Digital 2.0 (96Khz) or 2 channel DVD-Audio (192khz)?? Are they considered PCM (being 2 channel...) and hence affected by this setting (even if I'm configured to use "Bitstream")?? :confused:
    Or does PCM only apply to CDs and "stereo downmixes"? :confused: :confused:
  16. pknarb
    pknarb
    Aug 29, 2005
    47
    I would imagine "bitstream" is straight through with no intervention at all from the DVD player.
  17. Spacedog
    Spacedog
    That's what makes sense to me too, but I just wanted to make sure :)
    Thank you! :thumbsup:
