Help! PC DVD drive has locked to region 1
Discussion in 'Desktop & Laptop Computers Forum' started by Taz, Jan 1, 2004.
  1. Taz
    Taz
    Hi all,
    I have just noticed my DVD has locked its self to region 1 when I try and change it to 2 (it says 1 chance left) its saying I need to be an administrator (XP i am admin)
    So my question is.. how can I get the player back to region 2??
    A hack / crack would be useful as well.. the drive is a Mediatech mt1316b
  2. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    Try here for firmware cracks and info to unlock your drive.
    DVD multi region
  3. Taz
    Taz
    Thanks Graham
    The stuff I need is 'down' at the mo, will try again later:smashin:
  4. Taz
    Taz
    Still no luck, can anyone else see the firmware I need??
  5. tonyb
    tonyb
    May 14, 2003
    96
    Kent
    Hi Taz,
    Although this won't actually flash the firmware on your dvd rom drive, there are a couple of things you can try that will allow your dvd rom drive to play back titles from all regions on a region locked unit.
    DVD Region Free - trial available, otherwise $40 to buy.
    or there is a similar utility called DVD Region Killer. I believe the latest version is 2.7. Do a search with google or similar to locate download sites.
    Hope this helps to solve the problem....
    Tony
  6. Taz
    Taz
    Thanks for the advice Tony:smashin:
  7. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    It's telling you you have 1 more change of code out of the original 5 which are forced on users by the industry's protection-racket known as the "DVD Forum" .. so you can use your last change to set to 2 where it'll stay unless you hack it.
    On XP it requires you to be logged-on as Administrator so that there's less chance of, say, a family member using up the precious 5-changes-only without the 'owner' knowing.
    Here's a link for DVD Region Killer , though it's 2.5 not 2.7 as noted above. This is an older program which though free doesn't always work with current drives, DVD Region Free (above) and AnyDVD are paid-for programs which defeat region protection and a lot more besides.
  8. Taz
    Taz
    I am the Admin for this PC thats what I dont understand:confused:
    Thanks for the links but DVD region killer none of the sites are working for me.
    Thanks for the reply
  9. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Ah, didn't realise .. in that case I'm bemused. :confused:
    The link I gave you for AnyDVD and that Tony gave for DVD Region Free are both working for me .. if you can't get there then I suspect a proxy problem with your ISP.
    Try this link to Digtal-Digest for mirrors of DVD Region Free, the "official site" is the one Tony's link points to but this page also has some mirrors listed.
    Digital-Digest is a great site for DVD/DivX info, software etc.
  10. Taz
    Taz
    Will give that a go many thanks :smashin:
  11. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    If you still can't get anywhere I'll see if I can get them up to my domain and PM you a link.
  12. Taz
    Taz
    Thats got it :clap: Thanks, will look into a purchase of this software :smashin:
  13. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Great.
    DVD Region Free and AnyDVD are very similar .. I'm pretty sure there's a common code base somewhere .. so in case one doesn't work the other may.
  14. Taz
    Taz
    They both worked for me :smashin:
    If anyone has any UK ordering info that would be great
    :smashin:
  15. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
  16. Taz
    Taz
    Online is just fine :D
    Thanks for your help
    :smashin:
  17. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I just added the 2 links for the order pages if you need them.
    Glad to help. :D
