Help partition letter has change on hard drive can't access data
Discussion in 'Desktop & Laptop Computers Forum' started by pete18, Feb 11, 2009.
  1. pete18
    pete18
    Apr 14, 2002
    1,084
    41
    Torquay
    +3
    I had a power cut and when I went to boot my pc up again the partition I was using i can't access on my hard drive. I have 2 operating systems installed on my hard drive I can access c: but my 2nd partition was F: I am able to boot up my other partition c: and when I load up the other partition shows up in my computer but as now as D: I tried accessing the data from my computer but it's not letting me access it.
    Is there somehow if I changed the letter of the partition back to F: would I be able to access it as normal but not sure what to do.
    many thanks
    Pete
  2. andy1249
    andy1249
    May 7, 2006
    8,606
    +2,654
    Changing the drive letter is easy , see here
    How to change drive letter assignments in Windows XP
    You dont say what the main OS you are using is , but its pretty similar for XP or Vista
    Im not sure if thats going to help your boot issue though , see the warning at the start of the instructions.
  3. pete18
    pete18
    Apr 14, 2002
    1,084
    41
    Torquay
    +3
    hi
    andy
    thanks for replying i was able to change the partition back to F:
    but I have this blue screen come up when I go to boot the partition
    saying unmountable_boot_volume
    many thanks
    Pete
  4. pete18
    pete18
    Apr 14, 2002
    1,084
    41
    Torquay
    +3
    hi Andy
    i fixed the problem after I changed the drive letter back to f i did a chkdsk and it repaired the hard drive
    many thanks
    Pete
