Help Partial Erase Dmr-e55
Discussion in 'Blu-ray & DVD Players & Recorders' started by Cherbette, Apr 17, 2005.
  1. Cherbette
    Cherbette
    Hi guys,
    I just recently purchased the Panasonic DMR-E55 and apparently you can edit unwanted material out using the partial erase option but I can't seem to figure out how to do so. You are supposed to be able to go to the direct navigator and and select the clip then push sub menu and edit...then the option should be there but it's not...the only two there are "Enter name" and "Change thumbnail". In the manual I printed from the Panasonic web site it says I need to "Release protection" on the disc I guess in order to do so?? But I can't do that the way it tells me to either. Any ideas you guys? I really need your help!
    Thanks!
    ~Matt
  2. DAS
    DAS
    Feb 7, 2005
    61
    London
    What discs are you using? My E55 has that option under Edit, along with options to set up and cancel protection. Is your disc read only or seomthing?
  3. DRAMBO
    DRAMBO
    Feb 15, 2005
    157
    West Yorkshire
    +5
    You cannot partial erase a DVD-R disc with the E55. You need DVD-RAM disc to take advantage of the editing features.
  4. Cherbette
    Cherbette
    Thanks...I bought some dvd-ram discs and now it works.
