Help - Paradigm PS1000 Sub & Yamaha DSP-AX620 Connections
Discussion in 'AV Receivers & Amplifiers' started by rebdom, Jun 23, 2002.
Tags:
  1. rebdom
    rebdom
    I have just purchased a Paradigm ps1000 sub and wondered what is the best way to connect to my amp (Yamaha 620). The Paradigm instructions give 4 ways but I'm unsure which I can use with my setup:-
    1. Low Level Input - I assume is just connected via sub phono
    2. Low Level High-Pass Output
    3. Speaker Level Input
    4. Speaker Level Output
    I would like to use the best connection possible. I have KEF Cresta 1s front, back and centre.
    Any advice would be welcome.
  2. stranger
    stranger
    if you are using your sub mainly for movies just use 1.
    2 is if you are conecting two subs from 1 sub. out.
    ignore 3&4 unless you are using for music, as it can become a bit complicated-but post if you need to use these.
