Help!paradigm Ps1000 Power Lead
Discussion in 'Cables & Switches' started by alifreeuk, Jan 11, 2005.
  1. alifreeuk
    alifreeuk
    HI,now the pup is fully grown & stopped chewing :) it was time to dust the av equipment down & set it up,But by mistake half of my cables have been binned mistaken for rubbish in a black binliner DOH!so i need advice on where to buy or how to make a power cord for my sub!Any cable donations or any going cheap would be glady excepted,been away a long time nice to be back.Happy New Year!
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    You need a standard kettle lead (mains plug at one end, IEC at the other) with a 5A fuse IIRC. Loads of info on the forums about making your own if you want to though. Check the top of the Cables forum for a sticky on the subject. :)
  3. alifreeuk
    alifreeuk
    cheers john
