Help -Panny Viera Service Menu
Discussion in 'Plasma TVs' started by budwozza, May 3, 2005.
  1. budwozza
    budwozza
    Hi everyone, I am trying to find out how to access the service menu on my Panasonic Viera 42" Plasma (TH-42PE30)
    Can anyone help ?
    Panny 42" wall mounted - Well ace - fully recommended :thumbsup:
  2. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    don't know personally but have seen it posted a number of times...a search should throw it up
  3. DAS
    DAS
    Feb 7, 2005
    61
    London
  4. budwozza
    budwozza
    What I really want to find is the usage timer, I want to know how long I have been using it before I get it calibrated, any quick methods to find out
  5. DAS
    DAS
    Feb 7, 2005
    61
    London
    Follow the instructions in the above thread to get to Service Menu 2. Then use the green button to cycle through the options and you will end up at the "hours" indicator.
