help panny pw5 connection prob
Discussion in 'Plasma TVs Forum' started by titi, Sep 20, 2004.
  1. titi
    titi
    Please Help
    I have recently purchased a Panasonic pw5 37inch plasma display and have it connected up the following way.
    Sky box and Pioneer dvd 444 to js master scart controller
    Master scart controller into js rgb/plasma vga
    Plasma vga into screen pc port.
    Video recorder scart out with 3 rca straight into Plasma screen
    The problem
    Video works ok
    Sky works ok
    But the DVD player will not switchthrough the master scart controller
    It will only work if I connect it direct to the JS RGB/plasma VGA box and switch the panny over to PC.
    The Sky box and the DVD player are set to output RGB but on the Panny I only get pictures in 'Just' mode.Under 'RGB' mode it displays no signal.
    Any ideas ? :lease:
