Help Panny Problems
Discussion in 'Plasma TVs' started by stuartfoster, Jan 1, 2005.
  1. stuartfoster
    stuartfoster
    HI
    Newbie here hoping that someone can help me. I have had my panasonic PWD6 plasma for about a month and if was fine for first week then it started to develop a line of blocks which move down the screen I have tried disconnecting all the equiment and connecting in one item and also tried just connect in my PC and I get these blocks regardless of what is connected. I have attached two pictures so you can see what I mean.
    It may be that I have to call out panasonic so if anyone knows how to get the serial number of the screen without having to remove it from the wall let me know!
    Stu
  2. Andrew_P_S
    Andrew_P_S
    Definately looks faulty to me.
    The serial number is also on the sticker on the side of the box your plasma came in.
  3. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    Yes it does look faulty....take it back
  4. stuartfoster
    stuartfoster
    Anyone experienced this problem??
