help panasonic S97EBS
Discussion in 'Blu-ray & DVD Players & Recorders' started by compo, Feb 25, 2005.
  1. compo
    compo
    May 4, 2004
    153
    yorkshire
    Just bought a panasonic S97EBS to go with my th42pe30 it is not multi region does anybody have a firmware disc or know of a hack so that i can make it multiregion or point me in the right direction to someone who will upgrade it also is my plasma capable of displaying hdmi pictures
  2. TonyA
    TonyA
    Oct 16, 2004
    2,765
    London
    +217
    Why didn't you just buy a multi-region player?
    webelectricals.com do the S97 as a multi-region for £219
    T.
  3. Loada
    Loada
    Mar 4, 2003
    593
    Guisborough, North Yorkshire
    +51
    TonyA: That's a pointless reply, isn't it? He's already bought the non-multi-region player, that's why he's here.
    compo: You'll be pleased to know you can multi-region your player but it will involve getting hold of the service remote control. If you're lucky, and you know a Panasonic Repair guy, that's one way but the easier way for you, I'd guess, is to go here and get the disposal remote, should cost you £20. I believe other people have successfully used these in the past, you may wish to search the forum (or at least contact DVD Chips before you order and check what it does and what your comeback is).
    Hope that helps.
  4. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
  5. compo
    compo
    May 4, 2004
    153
    yorkshire
    will wait to see how u get on with your remote then may try one myself thanks
  6. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    compo...i used one of these from dvd chips for my panny dmr e55...it worked fine and was very easy to do ...just really a case of pointig it at your machine and then turning it off and on again....you get easy instructions on their web site so just print them out, follow them to the letter and you will be fine. Have subsequently ordered R1 dvds from playusa.com and they work a treat.......
  7. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    hi compo arrived this morning was a total breze to do only takes a couple of minutes !1
    i wonder if it will do more than one machine if so i am willing to post it on to you and if it works would you split the difference?
    jason
  8. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    it will only do the one machine
  9. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    has anybody confirmed this though??
    jason
  10. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    well try it now...put the battery back in and the light wont come on.....you would need to know how to reprogram it as obvioulsy dvd clicks use them again else they wouldn't send you a freepost address for returning them......for £20 its hardly worth the hassle
  11. compo
    compo
    May 4, 2004
    153
    yorkshire
    thanks lads i spoke to staff at westgate av in bradford i have bought a lot of stuff from them in the past and always had good service gave them a ring today and askes if they could do it for me they said they would do it for £20 quid so i guess i am taking it there
  12. xavk1
    xavk1
    Aug 9, 2004
    591
    28
    +36
    Guys,
    Just for the record, I used DVDchips one use only remote for the S97 and it worked a treat. Remained region free through a self adminstered firmware upgrade too!
    Xav
  13. Dave1112
    Dave1112
    how about a Panasonic DMR E55EBS DVD Recorder. They look like the real deal... Read the reviews, all pritty decent...
    Just curious about how long dvds actually last??
