HELP! Panasonic PT-AE700 Ceiling Projector Mount
Discussion in 'Projectors, Screens & Video Processors' started by PRINCEGRINCH, Oct 4, 2004.
  1. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    653
    +7
    Hi I've been searchHi, I've been searching the internet for Ceiling Projector mounts for my Panny AE700 Projector (which is yet to arrive). I Have found a celing mount that I like but im not sure if its compatible with the Panasonic AE700. The mount which I like is:
    Vogels Evolution EPC4010 Universal Projector Support
    http://www.av-sales.com/projectors/html/vogels_universal_supports.html
    Vogels Mounting Instructions PDF
    http://www.av-sales.com/projectors/vogels-projector-mount.pdf
    Could someone please take a look at this and let me know if it will work with the AE700. Also, since I'm getting a DRH Slimline 96"/104" Screen (viewable area is a 50 cm drop from the ceiling), would I be able to use the lens shift (if mounted on the Voguls - NO EXTENSION TUBE, Projector standard 11 cm from the Celing), to project the image on to the viewable area using the Lens Shift? Any help would really really be appreciated.
    Thanks.
    PS: If possible, could someone please post a pic of the bottom of the Projector so I can see how its mounted. Thanks again :)
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    I just get my dad to build mine :laugh:
    The first link looks ok to fit the ae700.
  3. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    653
    +7
    Thanks for the quick reply. If f only my dad could build mine :(
    Does the projector in the first link look like a Panny 700?
  4. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    I know that the panny has screw holes in a diagonal line. the first link looked like it is the same
  5. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    New Zealand was Nottingham
    +86
    If I where you I would visit Here . I have had 3 and they are awesome mounts. Have a word with Andy Patton and I am sure he will sort you out :)
  6. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    653
    +7
    Thanks for the info/help guys. The only thing wrong with the LMP Mount is that it doesn't seem to look as stylish as the Vogels (maybe its the pics), but it is cheaper, not by too much since I've managed to find the Vogels Mount for £101.39 Inc Vat (£30 less) at:
    http://www.robinsonselectric.co.uk/vogels_projector_brackets.htm
    I've just E-Mailed Vogels and am awaiting their reply. If they say that an AE700 can be mounted on it, then the Voguls Mount it shall be, if not, then the LMP Mount will have to do.
    My other question: Can I use the Vertical Shift as mentioned above to project my image correctly. Thanks
    Thanks again for your help :)
  7. sirp
    sirp
    Jan 20, 2002
    882
    28
    Derby
    +53
    another thumbs up for lmp here, they look fine m8, and do the job spot on
  8. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    653
    +7
    Does n e 1 know the dimensions of the LMP Mount or have a HQ Picture?
  9. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    +86
    Not exactly HQ but..... :)
  10. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    653
    +7
    Thanx 4 the pic Jack. It looks better than what I thought. Just that I'd prefer it closer to the ceiling. Thanx again.
  11. yeskyes
    yeskyes
    hi prince,
    did you buy the vogles mount? are u happy with it? I am looking for a mount and wait for your suggestion
    thanks
    yesk
  12. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    653
    +7
    Hi yeskyes, sorry I haven't bought the Vogels yet as I'm still waiting for my projector from Komplett. I will let you know as soon as I have it.
  13. Beano
    Beano
    I recently bought the Vogel mount which works perfectly with my AE700 and my living room :)
    I have a picture of the installation here :
    http://www.bean.dk/vogel.gif
    Sorry for the bad photo :|
