help panasonic plasma
Discussion in 'Panasonic TVs Forum' started by andrew24, Sep 19, 2007.
  1. andrew24
    andrew24
    Feb 16, 2007
    706
    46
    west sussex
    +133
    i have a panasonic plasma panel (TH-37PW7) the red light flashes twice on it i have had it looked at and have been told the Y SUSTAIN PCB has gorn in it. My question is can you by this part and would it be a big job so i can do it myself and how much would this likely to cost :lease:
    or should i be looking into getting a new plasma if so another panasonic or samsung or pioneer
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You probably can buy it, the diagnosis sounds right. Just google for it, or else buy a busted one on ebay.
