Help !! - Panasonic GS120
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by DeanE, Sep 30, 2004.
  1. DeanE
    DeanE
    Feb 14, 2004
    9,636
    +5,680
    Hello,
    I've just purchased a Panasonic GS120 after hearing the comments from people here and I've just recorded some stuff and want to transfer that to my PC. The DV-Studio software bundled with the camera seems to only allow me to capture a single frame from the tape.
    Sorry for the silly question, but how do I capture the entire thing and make an Mpeg/Avi etc .. ?
    Thanks for your help.
    Dean.
  2. Brian110507
    Brian110507
  3. vallhall
    vallhall
    May 21, 2004
    195
    Norway
    +16
    you have to buy you fireware cabel
  4. DeanE
    DeanE
    Feb 14, 2004
    9,636
    +5,680
    Thanks for your replies .. I'll get hold of a Firewire cable tomorrow, and I've got a firewire socket in my laptop so that's good news.
    I take it I will require different software to capture the video then ? Do you know if Vegas Video will be okay to use ?
    Thanks again,
    Dean.
  5. Brian110507
    Brian110507
    If you are capturing to a laptop then you may well need a 4 pin to 4 pin firewire cable instaed of the more normal 6 pin to 4 pin for a PC.
    Sony Vegas is an excellent capture and editing programme but some say a little complicated for a beginner and most say it's quite expensive - but if you already have it - give it a go.
    But if you are going to buy the Pinnacle Studio 9 and Ulead VideoStudio 8 are both good packages at reasonable cost.
  6. DeanE
    DeanE
    Feb 14, 2004
    9,636
    +5,680
    Thanks for your help Beejaycee !!
    Cheers,
    Dean.
  7. lurcher
    lurcher
    May 15, 2003
    4,216
    Stalybridge
    +221
    Dean,
    If you have got XP then you can use the Windows Movie Maker to capture dv.
