Last April I bought a Panny E85. It has had very light use since purchasing it. At the weekend i was dividing a few recordings when it froze. After 20 minutes I figured there was a problem so I turned the recorder off.
When I rebooted the machine it went through the self test but now the display is blank and no buttons on the unit or the remote control work other then the power off button?
Today I contacted Multiregion Magic where i got it from and they say it is a common fault and I have to post it back to them for it to be fixed. I am now worried as it only has 2 months warranty left and I don't want the same thing to happen as soon as the warranty is out.
The way the guy on the phone spoke about it, it should be a fairly simple thing to put right, he even reckoned I wouldn't lose any recordings on the hard disk.
Does anybody know what the fault is and how to cure it? I really don't want to be without my recorder for the near future and could do wothout having to package it up and get it delivered to Multiregion Magic.
I have tried searching the forum and found a post from somebody with the same problem but couldn't find anything else?
I'd really appreciate any help offered.
Many many thanks.
Many many thanks.
