pstables
Hi all, just purchased a Philips DVP5980 to connect to my Panasonic PT-AE500E. This works fine with my TV via scart but when connected to the projector via HDMI->DVI I get a picture for around 10 seconds, then the PJ screen goes blank and the PJ on screen menu (if displayed) flashes on and off (as if it's losing sync and getting it back) every couple of seconds.
I have used the PJ with a different DVD player with the same cable and it worked fine (although the black levels were shocking - but that was the other player which also went back).
I have tried the DVD player with a DVI enabled monitor and it works fine so I'm puzzled. Are there any settings on the AE500 0I can play with to get this working or will I have to try yet another DVD player (and if so, any suggestions as I want one that will also play DIVX).
Paul
Paul
