** Help! ** Pacific PHC203
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by kellucid, Sep 20, 2004.
  1. kellucid
    kellucid
    Does anybody know what the hack is for the Pacific PHC203 DVD Home Cinema System?
    I would really appreciate any help you can offer!
    Many thanks
    Kel
    xxxx
  2. pilchard
    pilchard
    Hi Kel
    I too have a pacific ph203 purchased from Asda this region hack will work :D
    I know it says its for a lenoxx HT-600 but i have used it to hack my pacific ph203
    How to change the region code of Lenoxx HT-600
    1. Press Power on from your remote control to boot up your Lenoxx HT-600(pacific ph203)
    2. Press the Open button on your remote control to open the disc tray
    3. Press the Volume button on your remote control until to the maximum value.
    4. Press the Language button on your remote control.
    5. The onscreen display will indicate the currently selected region
    6. Using the Down button on your remote control, change the region to 1 for region 1, 2 for region 2, and so on.
    7. Press the Enter button on your remote control
    Good Luck
    Col
  3. santana007
    santana007
    Aug 28, 2006
    173
    +5
    2009 ......... Lenoxx HT-600 .... :smashin:
    Rog :clap:
  4. Tombola2304
    Tombola2304
    Jan 24, 2012
    Please can someone help me, i need some information on how many times you can change the region code on the Lennox HT600?
    This would be a really big help.
