help out a dummy please
Discussion in 'General TV Discussions Forum' started by audievo, Sep 14, 2018.
  1. audievo
    audievo
    Aug 21, 2008
    65
    +15
    Hi, all.
    I am looking to put a screen in my store with a slideshow of my work on it. I want to fill an sd card or something similar with pictures and have them play on a loop all day. What would be best to do this on? Any tv's monitors with this feature built in? Yep i know little to nothing about this sort of thing. I know what i want to do but not how to do it, so as title says............. it's help out a dummy day
  2. simonlewis
    simonlewis
    Jul 31, 2014
    4,450
    stockport
    +1,645
    Can't you do it on a USB stick then put it into a USB slot on the tv and then select USB from the tv under sources.
  3. audievo
    audievo
    Aug 21, 2008
    65
    +15
    yes, so you can just plug a usb in and it will play images on a loop, is this on most tv's? sorry to sound thick, just not something i've ever done.
  4. simonlewis
    simonlewis
    Jul 31, 2014
    4,450
    stockport
    +1,645
    If the tv has a USB port which most tvs have these day's then yes you can.
  5. audievo
    audievo
    Aug 21, 2008
    65
    +15
    great, thanks, off to richer sounds thanks
  6. next010
    next010
    May 29, 2005
    10,702
    163
    +2,087
    If the way the TV handles images is not to your satisfaction, you can use a Raspberry Pi as digital signage with various software, some TV's can power a R-Pi from the TV USB port.
  7. audievo
    audievo
    Aug 21, 2008
    65
    +15
    Ok, thanks, it doesn't need to be top quality image, i'm just wanting a screen with a slideshow on a loop in the store all day for customers to look at.
