help ordered german Zelda
Discussion in 'Nintendo Wii-U & 3DS' started by djavs, Dec 30, 2006.
  1. djavs
    djavs
    Dec 19, 2006
    354
    Leicester
    +17
    Hi people
    I ordered a german wii which arrived on time and I also ordered Zelda big problem is zeldas come in a german case with german writing behind it and sealed up.
    I just wanted to know the games says PAL infront of it does this mean it will be english reason being i dont want to open it if its going to be in german
    also i did try cancel this order off amazon.de was being wierd saying its being sent even though i asked to cancel it.
    your help would be much apprciated.
  2. SHPanda
    SHPanda
    Dec 9, 2006
    152
    +6
    There will be a 5 in 1 language logo on the back cover at the top, seeing as the English version has the same thing on including Deutsch, so it'll be the same disc just with German as the default.
  3. psykix
    psykix
    Feb 7, 2003
    309
    Wirral
    +37
    It will use the default language set on the Wii console, so if Wii is set to English, the game will be in English.
    So worry not!
  4. cheshire_carper
    cheshire_carper
    Jun 28, 2004
    692
    +83
    If you see the word 'gut' it will mean something is good.
    Thus 'that was very gut link' will mean you did well.
    Hope that helps :rotfl: :rotfl:
  5. BA Baracus
    BA Baracus
    Whatever you do, just make sure that Link doesn't mention the war...
