Help: Options for 2nd TV.
BB3Lions
I've used the search but results albeit are similar are some 2+ years old and one goes back to 2004' I'm hoping technology may of moved forward since then.
I've ran a UHF cable from the downstairs TV using a junction box up and out to the upstairs bedroom, and there is limited signal. However if i unplug the cable i get a better picture. As i am pretty close to Winter Hill i guess thats the reason.
Anyway, a new TV beckons and i need a good signal to put freeview upstairs.
I have a standard TV aerial attached to the chimney breast, runs over the roof then down behind the cladding we had done :cool: this makes it impossible to gain access too to be able to use an external splitter, unless its fitted on the actual roof - open to all the elements...
So.. I'm in need of some advice please.
My info.
12 miles from Winter Hill NW England.
Old type - not been changed in i'd guess 10+ years aerial.
Options,
Replace the original cable, run this into the attic, use a splitter add one to the new TV and re-join the existing cable. (will need to pay someone to do that).
Cut the existing cable and put a splitter in a waterproof container and put this on the roof.
Use an internal aerial and put this in the attic, run the cable 2m into the TV directly.
Advice welcomed.
BB
Rodders53
No. RF technology is the same today as it has been for many, many years.
Read up Planning Your TV Installation and the associated pages on that site... all good stuff.
A 'junction box' sounds wrong... you need a UHF splitter to do this properly. Just joining cables together will cause problems. If a low-loss splitter has been used, with decent cable, then a amplified splitter (or distribution amplifier) should make up for the additional cable loss to the bedroom. {Assuming all connections have been made off properly and there's no stray whisker of outer shorting to the inner}
Use an XXXXXX aerial and put this in the attic, run the cable 2m into the TV directly.
May be the easiest. A proper external aerial though.
If you want to try a room aerial then by all means do so in the room so you can adjust it when needed.
BB3Lions
Hi Rodders,
Cheers mate. I phoned local aerial Co, £55 minimum charge for the cable, not inc additionals. I'm in the wrong business!
An outdoor aerial in the attic will do, you think? Hi gain or standard??
I'm out at the moment so I've got a chance of grabbing one now
Will read the link after.
BB
Similar threads
LG CX 4K OLED TV Review: The best TV of 2020?
