Help Onkyo remote control
Discussion in 'Home Cinema Control & Remote Controls' started by Scotlandgadgets, Feb 23, 2005.
  1. Scotlandgadgets
    Scotlandgadgets
    Cant belive it set up the surround system rewired and was just about to start programming and noticed the remote was lost.
    After 3 hours of looking for it the wife then mentioned she thinks she has checked it out :mad: :mad: :confused: :mad: :mad: .
    It is a Onkyo DR-L50.
    Have had a look on the net but cant see one does anyone have any ideas were i would be best getting one and what the price would be.
    Thx :clap: :clap:
  2. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,607
    Aberdeenshire
    +181
    Maybe not the best place, but probably the easiest would be a bar. I'm not sure of the cost....maybe a few Bacardi Breezers would do it - a new wife can't be that difficult to find. ;)
  3. Scotlandgadgets
    Scotlandgadgets
    Not sure about that but a few bad words were used. Just can seem to find anywere on the net that stocks them.
    Any help would be :thumbsup:
  4. Scotlandgadgets
    Scotlandgadgets
    I should have mentioned that i do have a proton 950 remote which am just trying to setting up so if anyone has the settings for the onkyo i would be most gratful.
    Or were i could get them.
    Have to say dont fancy setting up the surround sound with it but may have to.
    Getting desperate now. :eek: :eek:
