New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
I am trying to record VHS tapes to my PC through a link to my camcorder. this works ok then i use nero to transcode it and then write it onto dvd the process breaks down after about "5 to 75% i have a samsung dvd dual layer recorder hs552
Nero transcodes the file on the computer the problem comes when it has transcoded, when it is trying to write onto dvd, it writes anywhere between 5 and 75% and then it rejects the dvd, the media is memorex 8x dvd -r
Usually just means the DVDs are incompatible with your drive, try a drive firmware update. If that doesn't fix it buy different discs. There's some compatibility info on http://www.videohelp.com/dvdmedia that might help.
