Help on to make my XBOX progressive scan
Discussion in 'Xbox Forums' started by just wondering, Aug 4, 2005.
  1. just wondering
    just wondering
    Jul 25, 2005
    591
    Warwick
    +33
    Hi, Has anyone got a guide on how to make my xbox modded with component microsoft cable set to ntsc how to make the xbox Progressive scan ? i believe its to do with its ini file and hooking it upto my network...
    Anyone ????
  2. Pooon
    Pooon
    Dec 26, 2002
    7,126
    Canterbury, Kent
    +731
  3. scumball
    scumball
    Jan 12, 2004
    6,229
    Harrow - London
    +411
    You need to run the Enigmah Video Switch program and enable NTSC eeprom. Then in the MS dash you will have the options of 480p, 720p & 1080i. Enable all you want and you're off. The messing with files is to do with enabling 480p for the dashboard I believe...
  4. lasercutter
    lasercutter
    to switch the high def dashboard on (at least on later xbox versions) just hold both triggers in and click both thumbsticks down, repeating the process turns it off again.
  5. meansizzler
    meansizzler
    May 11, 2005
    7,582
    104
    London
    +266
    Buy an Action replay then PM Me...
  6. just wondering
    just wondering
    Jul 25, 2005
    591
    Warwick
    +33
    hi , the machine is already modded etc , in ntsc mode , i was going to network the xbox to my pc and hopefully do the change via a hex editor.
    Anyone have the full info.?
  7. tjradiohead
    tjradiohead
    Jul 29, 2005
    3,895
    71
    +58
    I have clicked pooontangs link, but couldnt find anything?
    Sorry for being such a noob... but can anyone else help me? i too want progressive scan.
    Will doing this stop me from being able to access live?
    Thanks in advance
  8. Pooon
    Pooon
    Dec 26, 2002
    7,126
    Canterbury, Kent
    +731
  9. Colgate7110
    Colgate7110
    Sep 12, 2004
    768
    28
    Glasgow
    +75
    If the machine is already modded and in NTSC mode, do not just go into the Xbox dashboard system settings and in the video/display options you enable 480p, 720p and 1080i as appropriate? On a PAL system this is where you choose the TV shape (4:3, 16:9) and whether PAL60 is supported.
  10. stu.artd
    stu.artd
    Jul 29, 2005
    3,865
    +328
    I have an NTSC XBox, bought when it was first relesaed in the US and imported it to the UK. I don't see any 480p etc.., I just see 4:3, 16:9 and letterbox.
    How can I enable those options ?
  11. Colgate7110
    Colgate7110
    Sep 12, 2004
    768
    28
    Glasgow
    +75
    Hi stu.artd, do you have the Advanced AV kit? It's Microsoft's component lead with the break-out box to connect component leads, L/R phono audio leads and an optical digital out? Even on an NTSC configured box, without a component connection you can't access the HD modes, i.e. it won't work via the Advanced SCART/RGB, s-video or composite leads. I'm not sure if you strictly need the MS HD pack or any component lead will do - hopefully someone on the forums has experience of third party leads here.
    Cheers,
    Colin
  12. stu.artd
    stu.artd
    Jul 29, 2005
    3,865
    +328
    You've hit the nail on the head, I don't have the Advanced AV kit, that explains it. Thanks for the info, I'll see if I can get hold of one.
  13. Spacedog
    Spacedog
    I've read some testimonies which indicate that the best results are achieved using the genuine M$ High Def AV Pack. Third-Party leads can (i'm just saying what i read while surfing the net, not by my own experience) make your image look kinda crappy ;)
    I can sugest you look for it in Lik-sang.com or dvdboxoffice.com
    Happy hunting!
