Help on the TH42PW5B
Discussion in 'Plasma TVs Forum' started by Corazonis, Sep 28, 2004.
  1. Corazonis
    Corazonis
    I've had my panny series 5 for some time now and i'm looking at ways to remove the need for the tuner box. The reason for this is so I can access the screen only options (like defaulting the channel to AV1, etc). This has been a thorn in my side for some time, although the tuner box does allow a lot of connections into the plasma.
    What's the easiest way to remove the tuner but have many input sources. I'm especially hoping to retain the component connection for DVD, but I still need a way to feed the display with Sky, XBOX, etc.
    Any help would be appreciated.
