Help on subs
Discussion in 'Subwoofers' started by deff, Mar 28, 2002.
  1. deff
    deff
    Jan 29, 2002
    34
    Iam looking at one of these three, Paradigm ps1000, Mjaccoustic pro50 and a sub from Bose (dont know which one as yet)
    What will better buy. Can't spend more than £300
    Deff
  2. uncle eric
    uncle eric
    Deff,
    Forget the Bose. This is a mid-woofer.
    Try and demo the other two if you can. They are both decent for the money. Alternatively, for 300 pounds, better subs (used) can be had on the classified section from time to time.
    Eric
  3. deff
    deff
    Jan 29, 2002
    34
    uncle eric, I have a small room and don;t a big sub. What can you recommend for a better used sub
    deff
  4. deff
    deff
    Jan 29, 2002
    34
    One that I missed of the list. Has anyone auditioned the VIBE Alpha
    comments pl-eeee-se
    Deff
  5. dts_boy
    dts_boy
    Nov 26, 2001
    2,669
    Manchester suburbs...
    +215
    i was in a sevenoaks shop theother day and heard the asw1000 running, i was amazed. i asked how much and they said guess. i have a m&k vx100 and thought that this thing was not too far off (£600 -800ish). in actual fact it is £300 and a damn good buy IMO!!!
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    deff: The Vibe Alpha 1 is a very good little sub for the money, can go very loud when required. We had one in for demo from Vibe last week and I was very impressed.
    dts_boy: The ASW1000 is £500, the ASW500 is £350.
  7. eddiea
    eddiea
    My listening room is small so I tried the Mjaccoustic pro50, while it gave a form of LFE for DVDs it was not very musical.
    I settled on a REL Strata III after trying the Q150, Q200, Q400 and Storm III.
    I would recommend you try the Rels
    regards
    Eddie:)
  8. petrolhead
    petrolhead
    Mar 29, 2002
    4,871
    87
    Newcastle
    +123
    If you can aford REL then get one.
    I have a Paradigm PR10. Great for the price £150 from Ritcher Sounds. And not too big. Tip - I wanted my sub not to be seen so I bought a cheap chipboard round table and cut 12" off the bootom of the legs. Then put this on top of the Sub with a table cloth over - hey prest a table and sub in one :)
    There is a review here http://www.smr-home-theatre.org/Interface.html Go to Hardware Reviews - Paradigm
    Good luck
    Peter
  9. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    essencial home cinema mag have a sub shootout in this months edition
    the mja pro50,rel 150 and i think the vibe also
    they give the mja pro50 5 stars,which im glad of,as i bought one last week without hearing it first.its been getting great reviews.
    suprisingly they only give the rel 3 stars
    carl
  10. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    I thought that there was a profanity filter on the forum
  11. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,714
    A truly fine publication!:p :D
  12. deff
    deff
    Jan 29, 2002
    34
    Thanks for your replies. I am still none the wiser as to which to go for. Codling how are you finding the mja pro50.
    Has anyone investigated the yamaha yst-320
    deff
  13. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    deff
    still havnt set it up yet,as im still doing my room,wont be able to try it for another few weeks.
    carl
  14. Me
    Me
    Aug 17, 2001
    132
    Wiltshire
    +5
    deff
    you could have a go at bulding your own sub or re-building a Yamaha one. The amps in the Yamaha subs are ok and cheap, but need a little work. Good fun.
