Help on Speakers ....
Discussion in 'Home Cinema Speakers' started by Midnight, Jan 14, 2001.
  1. Midnight
    Midnight
    I'm currently loooking at buying a complete system. I went to Richer Sounds yesterday and they advised Eltax Synphony 6 for the front, Gale Monitors for the rear and a Eltax Symphony Centre. Additionally, they are recommending a Eltax A10 Atomic.
    Is it best to have matching speakers or is mix and match acceptable ? They are unable to demo at the moment coz they are having a sale.
    Any suggestions ? Many thanks in advance
    me
  2. Kev S
    Kev S
    I would get an audition booked in with them before buying them.
    I know that Richer Sounds are busy during the weekends but they should be able to give you a demo during the week
    (perhaps phone them to book in a demo). After all it is your cash you are handing over and you are going to have to listen to them a lot longer than the sales person.
    In an ideal set up I have always been told that you should try to match speakers across the front/rear (Timbre matching)
