help on putting files in trash
Discussion in 'Apple Forum' started by bluraymond, May 7, 2007.
  1. bluraymond
    bluraymond
    Feb 8, 2005
    362
    28
    +47
    I'm trying to put something into Trash but the OS gives a message that
    it is still open but it's not, does anybody know what I should be doing? any help greatly appreciated.
  2. jont
    jont
    Apr 8, 2002
    4,335
    near Aylesbury
    +577
    what are you trying to trash ? a file/picture/mp3 ? or something else ?
    It might be in use by a bit of teh OS ??
    Try restarting with the shift-key help down (so as not to load any user-specific items) move the item to teh trash and then hold down the option/alt key and select empty trash ...
    Jon
  3. bluraymond
    bluraymond
    Feb 8, 2005
    362
    28
    +47
    Thanks for the advice, the file is now gone:thumbsup:
