help on new dvd player needed
Discussion in 'Blu-ray & DVD Players & Recorders' started by RobTi, Jun 1, 2005.
  1. RobTi
    RobTi
    Dec 11, 2003
    2,491
    Hamilton
    +141
    need to replace my player as i want to try sacd and dvda also need progressive scan and component out for projector also multi region and the ability to play back up discs.
    So any help on which one to go for?
  2. ilrenato
    ilrenato
    Nov 26, 2004
    23
    yamaha s2500 or if you skip the sacd the oppo/bbk dv971h panasonic S97 is also good.
  3. Br41ns
    Br41ns
    Apr 5, 2005
    424
    Glasgow
    +31
    :hiya:
    All depends on your budget but there are plenty of good ones from £150 upwards. Ive got a samsung hd945 which does everything you want and is very good value for money, do a search on the forum as theres alot to read on the pros and cons of all the machines.
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    Also have a look at the Pioneer 575...PJ :)
  5. RobTi
    RobTi
    Dec 11, 2003
    2,491
    Hamilton
    +141
    Thanks for the help guys £150 is my limit at the moment so will look at the samsung and pioneer thanks
    Robert
