help on my system
Discussion in 'AV Receivers & Amplifiers' started by naimesh, Jul 22, 2003.
  1. naimesh
    naimesh
    my kit pioneer 50 plasma
    pioneer ax10i amp 6- 16ohm(170 per channel)
    monitor audio gold ref 20 fronts, centre (150w)
    left/ right moitor audio grx
    rears m&k ss150 thx 4ohm
    toshiba dvd 9500d
    can you help, i am looking to improve my system in sound quality
    if i put some power amps on the system will it help and which do i buy appx £1000 each and which speakers do i get them for
    thanks
