Help on importing a US player
Discussion in 'Blu-ray & DVD Players & Recorders' started by THX 2208, Aug 30, 2007.
  1. THX 2208
    THX 2208
    Aug 30, 2007
    10
    Hi guys new to the forum. My current set-up is a Pioneer PDP-436PE. Marantz 7600 DVD(HDMI) and SKY HD. I was thinking about the importing the Toshiba HD-XA2 from the US as 90% of my disks are R1. The main question I have is the XA2 better than the Marantz for upscaling SD disks or should I go for the US version of the EP10. Thanks
  2. paulst10
    paulst10
    Dec 16, 2004
    12,849
    Essex
    +2,294
    hi, welcome to the forums
    if this is of any use to you
    i once had an arcam dv79 dvd player and i thought the upscaling on the toshiba HDA1 was pretty much as good as the arcam .. and within a couple of weeks i sold the arcam and bought my old pioneer 565 back cheap for PAL & other region disks :smashin:
    i would imagine that the XA2 would be a better upscaler than my HDA1 as the XA2 apparently uses the far superior reon chip .. and going by some of the online reviews i have read .. i dont think you would be dissapointed.
    best of luck
    paul
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Did the 79 have upscaling? It has been a while since I have seen one....and the momory is not what it once was.....
    The XA2 is a lovely player and pretty much the top of the DVD pile. Worth looking at the secrets test here, mind you the Marantz ain't bad at all.
  4. paulst10
    paulst10
    Dec 16, 2004
    12,849
    Essex
    +2,294
    oops, should have pointed that out.
    no the dv79 didnt upscale but did have HDMI .. IMO though .. the arcam non upscaling was as good as if not better than most of the newer upscaling players costing around the £600 mark (which im sure was the rrp of the marantz 7600)
    i was just using it as a comparison .. as i was in the the same situation a year ago .. and was also unsure whether a £400 hd-dvd player could be as good as my £1000 arcam :)
    paul
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Thought I was loosing my marbles for a minute, will have that drink tonight after all!! 79 was one of the great DVD players in my book but the XA2 is better.
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
  7. THX 2208
    THX 2208
    Aug 30, 2007
    10
    Thanks think I will go for the XA2 but I still love my 7600 will use it for my small collection of R2 disks :thumbsup:
