help on freeview & panny Viera
L
lee-s
need to know the score on how to get extra channels with the built in freeview box. i think i need a cam.
has anyone already got this in theirs, if so whats the best place to buy one from? then i take it i just need to buy a TUTV card
:lease:
fitguy
are you getting any to start with??
If youre not getting any/too many of them it may be a bad signal (check via the menus).
If you have the free freeview channels and are after the rest (E4, Discovery etc...) then yes you do need the CAM and card.....still looking for a decent offer on these myself!
L
lee-s
kool, cheers for the reply.
yes im getting the normal ones , but i want extra ones like yourself.
how much are these cam things and where can you buy them from then?
fitguy
Ive been looking for a cople of months. Unless anyone can tell me otherwise ive not found them cheaper than the high street stores (currys, dixons etc...). Even the ones on ebay end up going for £40 (theres one there now currently at £35.00).
L
lee-s
had a little look about, can i only use a TUTV CAM for this service or can you use an ON digital CAM with a TUTV card anybody know??
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
