HELP!!! - on DTS signal
Discussion in 'AV Receivers & Amplifiers' started by saggu1, Jun 22, 2001.
  1. saggu1
    saggu1
    I have a Toshiba SD100E DVD player and a Yamaha DSP-A5 amp. The trouble I am getting is that when I play Gladiator I cannot get the amplifier to reproduce the DTS sound coming from the DVD. I have a CAMBRIDGE optical going into the amp.
    Please advise coz I am dying to hear what DTS sounds like!!!
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    One of 2 things I can think of :-
    1 - You didn't select the DTS track on the DVD (by default it uses the DD track).
    2 - You have DTS output disabled from the DVD player (I don't know the Toshiba players) but there is usually a menu that allows you to specify DD, DTS or MP3 outputs.
    Hope this helps a bit.
    Slingshot
  3. paiger
    paiger
    If it's a DTS amp and you have a digital input and auto-detect selected then the problem must be at the DVD end. It's worth it to get it working, I prefer DTS to DD, dunno why, just a bit atmospheric or something.
    S
  4. saggu1
    saggu1
    I realised that you need to select the dts option on the DVD..duh..
    cheers SLINGSHOT!!! :D
  5. Guest
    Duh indeed!
  6. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    I will confess to having exactly the same experience 1st time I tried to play DTS.
    I mean whilst it seems obvious once you think about it, it doesnt leap of the page anywhere that you need to select a different sound track.
    My son and I read our receiver and DVD player instructions from cover to cover trying to find out how to switch DTS on. There was not a single referrence in the manuals (Onkyo and Philips) as to how to do this.
    Nor on the DVDs we tried was there any instruction as to the fact you need to select a DTS soundtrack.
    So, it might be obvious once you know, it might be a bit of a 'duh' moment, but you would think somewhere it would tell you.
  7. saggu1
    saggu1
    Cheers Ioz for the back-up here!!! :p
