help on conecting to a Z1
Discussion in 'Projectors, Screens & Video Processors' started by RobTi, Dec 19, 2003.
  1. RobTi
    RobTi
    Dec 11, 2003
    2,491
    Hamilton
    +141
    just got my Z1 and am confused about which connections to use for viewing.
    I have the following
    dvd with comonent out
    laserdisc with either rgb scart or svhs
    tivo with rgb scart.
    i assume the dvd with the coponent out but the others i need help with.
    :confused:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    do you have an AMP with YUV switching?
    If so get an RGB>YUV converter for Tivo and LD or an RGB>S-video and do the same.
  3. RobTi
    RobTi
    Dec 11, 2003
    2,491
    Hamilton
    +141
    no amp only has composite switching so stuck i didnt know if i could convert the rgb to yuv and have the 3 split into 1 cable going to pj
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    go for RGB>S-video then you must have run more cables!!! If not then that is a little silly every connection on the PJ should have a cable running back to equiment!
    I guess your gonna need a component switching unit.
  5. RobTi
    RobTi
    Dec 11, 2003
    2,491
    Hamilton
    +141
    any recomendations for a switching unit?
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    have a search loads of info on here and some in gaming forums
  7. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Check the maplin catalogue. They do a B-Tech audio/video switching unit (3 in, 1 out). I used one for a while and it was excellent. Only meant for composite video and L/R audio but worked a treat for component. It has a manual switch to select the input but I opened it up and with a bit of soldering bypassed the switch so wahtever was fed in was passed out.
    Cost £15 IIRC.
