Help on Alphason AD5/47-S
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by happyhiker, Jan 22, 2005.
  1. happyhiker
    happyhiker
    Jan 3, 2005
    421
    +26
    Can some one answer a question for me.
    I'm thinkin gof gettin gan Alphason AD5/47-S, nowever my amp is 44cm deep and the info onthis stand says Support 38cm min , 45cm Max. Does that mean the top shelf is 45cm deep but all the rest are 38cm ? I don't wan tto put the amp on the top shelf. Ideally the 3rd sheld, or the bottom one would be fine.
    Does any one have a Alphason AD5/47-S they could measure the shelf depth and see if a 44cm square amp will fit ?
  2. Dankeech
    Dankeech
    Feb 1, 2005
    3,624
    Stevenage, Herts
    +298
    I know it's a year late, but was browsing looking at these stands myself. Think it's the cable-tidy that stops you from mounting longer amps as it gets in the way a bit.
    Dan.
  3. Simian Sibling
    Simian Sibling
    Jan 18, 2005
    6,553
    Brentwood, Essex
    +1,151
    Again nearly a year to late but..
    did you buy on of these dankeech?
    if so what is it like as i am thinking of getting one
    Ben
  4. Dankeech
    Dankeech
    Feb 1, 2005
    3,624
    Stevenage, Herts
    +298
    Friend has one of these. It's the silver and clear glass one.
    TBH, having clear glass means you've got to do a good job of tidying cables behind the unit, but altogether it's fine as a unit.
    Don't think it stood out as spectacular in my book, there are IMHO much better looking racks if you're willing to step up a little on the price or go second hand.
    Ones that have previously caught my own eye are:
    Quadraspire Q4, can be had at £200 or less and I had seriously considered going for one of these, but I'd already bought my Partington minim at a silly low price at the time.
    http://www.quadraspire.com/product_range/q4/page1/index.html
    Still, the Alphason is fine - just for me doesn't have the wow factor, but seems very stable and solid and will serve its purpose well.
    hope that helps.
    Dan.
  5. Simian Sibling
    Simian Sibling
    Jan 18, 2005
    6,553
    Brentwood, Essex
    +1,151
    Thanks for the reply.
    I have had a look at the Quadraspire Q4 and first off was wow, but, having had a better look at some pics its not really my cup of tea.
    I guess the search will continue!
    Thanks for the info
    Ben
  6. Dankeech
    Dankeech
    Feb 1, 2005
    3,624
    Stevenage, Herts
    +298
    Thinking about things, without the Cable-Tidy installed it is highly likely a deeper amp will fit.
    I'll be over a friend's house in Harpenden at some point i the next 2 days and will take a look myself and update the thread if I remember. Keep an eye out on the thread.
    Dan.
