help on a new screen
Status
Not open for further replies.
HCking
just need some advice on a screen choice
my screen is 42"x74" viewable area, and wish to upgrade from the painted mdf that i have now.
what reconendations do you have
my equipment is
sony 1270
quadscan pro
extron 202xi
showing dvd only at line tripled (720x720)
i dont have a colour/contrast problem just wanted a better screen to show the films better
what, why and how much is what i need to know
cheers
Mark
Gordon @ Convergent AV
AVForums Sponsor
If you have painted MDF then I presume you you can go with a fixed frame screen. If so the two I think are nice just now are OWL's own fixed frame unit and, of course, the Stewart Luxus Delux screenwall.
I'd guess that 6ft wides are going to be from £700 upwards but need to check. If you email me at convergant I can give you an accurate quote later.
If you are looking for manual or electric screens then there are many others to consider, along with how you would want to control the thing.
Gordon
HCking
Thanks Gordon
i will want a fixed screen as its in a dedicated room, i will email you for a price etc
thanks for the reply
Mark
meep
Mark,
You could go the DIY route - see my website.
Also, check out the screens forums
Peter
Hi Mark,
Some have tried using curtain blackout and covering say a painted MDF.
Personally, I cut off the screen from my old roll up, and stapled it to the plasterboard wall, got it perfectly flat, then over stapling black carpet to frame it.
These screens seem ok :-
http://www.crtprojectors.co.uk/screens.htm
Rgds
Nathan
fatrich
Mark
i bought my screen from Owl video , its a 6ft wide screen fixed with velvet boarders and the screen materical is equivelent to the stewart studiotek 1.3, it retails at £800.00.
Where do u live? i have an unfinished screen project if your interested, which includes a quality screen material (i think it 1.00 gain)
an industrial stapler and 3 meters of Black velvet, if your interested you can have them £50.00 + postage
cheers
richard
HCking
rich
i was thinking about someting with a gain of about 1.3-1.4
i will keep your offer in mind though
thanks
Mark
fatrich
No Problems
just let me know
cheers
richard
buns
what screen material is the best for crt? The perlux stuff i have found info on claims it needs viewing dist greater than 5m.
ad
meep
The Perlux 1.4 gain I use is viewed at around 3-4 metres. No problems. Any closer and you do see the screen structure on white areas of an image (a kind of dimpled effect)
Regards
Peter
buns
hmmmm, i wil probably be about that..... with my current pull down job, i cant see the screen structure at all...
are there any other alternatives?
ad
Status
